Looking for the best video software to edit some video I've got.
Mostly looking for something to do scene transitions, like fade in/out
that kinda stuff. Nothing complicated
I've got premire 6.5, but it seems to only export/save as .AVI.
All the video I'm working with I encoded through tmpgenc plus.
Anything else out there that easy to use and works with mpeg2 video
both import and export?
thanks.
uhm... Premiere 6.5 has MPEG2 support... That's the big change in 6.0 and 6.5
Actually, you only need to become adept at AviSynth to do all those functions with TMPGEnc. However, it is an advanced piece of software.
Until then, try Ulead Video Studio 6. It is easy to learn.Hello. -
Vegas Video 3.0
I use it for everything. Pretty easy and has alot of cool transitions. And you can encode to MPEG2, and I think the quality and speed is really good. -
Originally Posted by Toogy
Now to figure out how to make a transition in video, I can do it, but the transition is like 1 frame long.. gotta figure out how to extend it. The documentation is a little lacking.
-d -
You should definately check out AVISynth when your ready. It's got a powerful built in tool set, but it isn't newbie friendly. It will do blends, fades, etc, via scripts.
Impossible to see the future is. The Dark Side clouds everything... -
Mavrick's right.
However, I tried using the Adobe MPEG encoder and while the results were OK, I still get better results converting the Adobe AVI with TMPGEnc.
To me it's worth the effort. I love Premiere. I've only had Pinnacle to compare it with, maybe this Vegas Video thing is pretty good too, but make sure you do small test projects with all new software. You don't want to spend weeks working on something, only to find out that the application has bugs so severe, that you can't even output to tape!
How Do All You People Learn All This Stuff About Editing???
By JohnnyGalaga in forum EditingReplies: 37Last Post: 10th Nov 2011, 01:09 -
Menu editing after adding audio track
By Instant Martian in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2011, 11:23 -
please help me choose software. Open source or low budget stuff
By phoenix777 in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 08:25 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Which laptop is the bes for video editing and stuff?
By Kashi169 in forum EditingReplies: 8Last Post: 10th May 2010, 09:30
