I am (trying to) convert a 3h 45M VHS video to something that can be read on PCs and Macs. Would I be better creating VCD or DivX?
What are the pros and cons?
I have a WinTV PCI FM (Nicam) card; XP Home; Athlon 1.6GHZ, 512MB Ram; 40GB free disk; Audigy sound card.
Mike
	Divx will give you much better quality than VCD (if captured properly), the downside is you will not be able to play a divx in a standalone DVD player. If you value these files then capture to both, Divx capable DVD players are prolly less than a year away....
	Ay, there's the rub... Any recommendations?Originally Posted by mh2360
 Good idea. Convert to both and give my patient people the choice...Originally Posted by mh2360
 Thanks.
 Mike
	BTW, although MPEG-4 capable DVD players are coming, don't assume that they will play back your exisiting discs!
 Regards.Michael Tam
 w: Morsels of Evidence
  Convert A DivX with AC3 To VCDBy Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 04:55
  VCD to Divx conversionBy silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25
  Divx to VCDBy d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19
  VCD to DIVX ConversionBy DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28
  DiVX (AVI) to (S)VCD using DVD2SVCDBy LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
