Why do VCD audio files burned onto DVD media need to be in 48khz? Will newer DVD players be able to read 44khz audio files on DVD media?
http://www.vcdhelp.com/vcddvdr.htm
I want to eventually put my VCD files onto DVDs, but don't want to spend the time converting the audio, if newer players make this unneccesary. Is the 48khz intrinsic to DVD media?
If I don't convert it, will these files be playable on my computer? Or on a Apex machine?
the reason they're 48hkz is just a DVD standard. it's a higher frequency than CD and so if uncompressed audio is used the sound quality will be better.
obviously using VCD-encoded mpeg's was not the intention of the standard.. it was, as i said, to provide higher-quality audio than CD.
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
DVD standard requires 48000 sampling rate. If your converting VCD or SVCD to DVD-R you convert the audio to 48000. No authoring program will except 44100 for a DVD and no DVD player will play a DVD made with 44100 audio.
thanks for the responses, geek rock and wulf109.
If is convert all my vcd files to 48khz, will they still play if I burn them on CD-rs? Or would the DVD player not recognize it? -
That depends on your DVD player - some will play your CDR VCDs with 48000Hz because it is a DVD standard anyway, others won't since it is not a VCD standard.
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
24bit/48kHz for DVD
By iker222 in forum Authoring (DVD)Replies: 11Last Post: 3rd Aug 2009, 08:59 -
32khz mpeg to 48khz how to ?
By Videodream in forum Capturing and VCRReplies: 12Last Post: 4th Aug 2008, 10:11 -
DVD-NTSC PVR/TVR capture isn't 48kHz as set to
By wguru in forum Video ConversionReplies: 0Last Post: 28th Jul 2007, 03:38 -
Why was 48khz needed for DVD specs?
By yoda313 in forum AudioReplies: 3Last Post: 7th Jul 2007, 16:57
