What is it and how do I know what my movie has? (or is?)
Interlaced video basically splits the video into two fields, which are rendered in two passes to produce the whole image. There are some technical details having to do with frequencies and such that are the cause for this, but the short of it is that the maximum scan height for NTSC is 240 lines, so to construct video with 480 lines, interlacing is necessary. I believe this discussion doesn't apply to PAL or SECAM. (Anyone who believes otherwise, feel free to chime in here).
So how do you know if video is interlaced? Basically, if its height is 480 and it is NTSC, it is probably interlaced. Otherwise it is likely progressive (i.e. videoCD at 352x240 is progressive, DVD at 720x480 is generally interlaced).
Of course, the easiest test is how it looks on your computer. Computer moniters handle interlacing poorly, and the artifacts will be fairly obvious.
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
Progressive and Interlaced Chroma -- again!
By Anonymous344 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Apr 2011, 07:14 -
de-interlaced means progressive ?
By codemaster in forum EditingReplies: 19Last Post: 23rd Dec 2010, 06:08 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41 -
Progressive vs Interlaced Regarding Motion
By Brent212 in forum Newbie / General discussionsReplies: 6Last Post: 15th Jul 2009, 19:26
