I have a TDK veloCD 12/10/32 and i bought some 99min cds and i was wondering if i could overburn i have nero 5 and i enabled the overburning feature and it still does not work. can someone help me with this topic??? thanks
Ok 1st of make sure you have NERO 5.5, It supports overburning up to 120min. or 1050MB.
After staring up NERO go to the prefrences and change your overburn to read 98min. 15 sec.
Do not change your yellow of red markers leave them at 80min.
Use only 8x or slower burning speed. anything faster you might get errors.
Make sure you are not going over 98min. on music, VCD, SCVD or 1 gig on data.
On data you can not overburn in ISO.
Overburn only works with Disc-at-once turned on only.
These settings work perfect for me.
I have burn many SCVD's at 90 to 98min. use on these CD's.
I am using a HP 8x4x32x burner.
The 99min. CD-R's I bought were at CompUSA.
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57
