I am having trouble opening some AVI files in vertualdub. I have used it before to convert audio to .WAV and it hasworked fine. I am using the latest version (1.4.10). Every time I try to open some AVI files I get th following error message....
"Couldn't locate the decompressor for format 'DX50'" (also XVID)
"Virtualdub requires a Video for Windows (VFW) compatible codec to decompress video. DireceShow codecs, such as those used by Windows Media Player, are not suitable."
I have installed Nemo Codec pak. As I said before, I've never had a problem. It seams that I have onle had a problem with AVI's from DVD rips. I have spent a lot of time reading the how to sections and forum posts and can't find an answer. Can someone please help. I will try to help others as I learn. Thanks in advance......Dockdog 8)
Knowledge is power. Help to make everyone as powerful as possible.
The only thing I can think of is try to reload Nimo Lite Codecs.
Hello. -
hi,
i used a application called mpegable which i downloaded from download.com, and while i have only had it for a few days, it opens all the movies i have, which before showed the same error message.
hope this helps, job -
Thanks for the advice. I will try to reload Nimo today. If no good I'll download Mpgable. I really like Virtualdub because it gives so much info on files. Well I guess you can't have it all
. Thanks again......Dockdog
Knowledge is power. Help to make everyone as powerful as possible. -
I have the same prob after installing nemo pack. Have reinstalled Virtuldud and nemo. Keeps saying the same thing. But again only since insatllin the nemo pack!
You need XviD codec before you can open it in Virtual Dub. Get it here:
http://www.divx-digest.com/software/xvid.html
Regards -
yeah, that will solve the problem
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Thanks for all the help
I installed the Xvid codec and all is fine with Xvid AVI's. I tried to reinstall Nemo but it did not work. It was weird, although I saw DivX 5.0.1 in multimedia properties on my computer, it did not show in Virtualdub. I downloaded DivX 5.0.2 and it works great. I couldn't have done it with out everyones help. I hope Mike229 who is having the same problem reads this. thanks again............Dockdog.
I'm trying to open .WebM in VirtualDub
By alinhoalisson in forum Video ConversionReplies: 25Last Post: 22nd Sep 2014, 06:20 -
Open h.264 in VirtualDub
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 6th Nov 2011, 21:21 -
How to open WMVA with VirtualDub?
By Zeokat in forum Newbie / General discussionsReplies: 5Last Post: 24th Oct 2011, 04:47 -
can't open flv in VirtualDub
By shun in forum Video ConversionReplies: 3Last Post: 26th Jul 2010, 19:10 -
Virtualdub can not open xvid
By quxote in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 01:11
