I am planning on purchasing a USB capture device. But there is so many to choose from. Which is the best and affordable? I'm looking for a device that would capture and make MPEG-1, MPEG-2, VCD, and SVCD from a camcorder, a vcr, and from movie files on the PC in pretty good quality. So far, I came across these:
ADS's USB Instant DVD
http://www.adstech.com/products/USB_Instant_DVD/intro/usb700.asp?pid=USBAV-700
Digital Video Creator 150- Dazzle
http://www.dazzle.com/products/dvc150.html
Digital Video Creator 100- Dazzle
http://www.dazzle.com/products/dvc100.html
Would anyone recommend any of these products? Would anyone recommend any other product?
Thanks.
I would'nt reccomend any USB capture device with hardware mpeg encoding. To get great quality you need to capture to uncompressed AVI, or use a lossless codec such as huffyuv. Then convert using a software mpeg encoder such as TMPGEnc. The whole process takes a lot longer but the results are much better.
Craig
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 10:16 -
Capture device
By ingeborgdot in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2011, 21:02 -
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 18:23 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 15:30
