I have a question about VCD recording. I have succesfully coverted a AVI to a VCD to play on a standard DVD/VCD player. The problem is that the VIDEO quality is very poor. I am uising VIrtual Dub V1.49 and added 2:1 reduction (high quality filter) and DIVX 5.0 for video/compression and 1150Kbps. Also full processing mode on Audio and 44100Hz conversion/sample rate. I am using TMPGE for encoding. I opened the AVI inforamtion for fps and it was 11.988 so I selcted the standard NTSC. The last step I used CDRWIN 5.0 to burn to a 80min/800 MB cd. If the FPS are as low as stated above will I never get a good quality VCD. What is the lowest FPS I should use inorder to convert and burn a quality VCD??Thank you for your time in advance and I appreciate any suggestions you have.
Once you capture to Virtual Dub, I suggest frameserving to TMPGEnc. Then before starting the frameservice, use the appropiate TMPGEnc template with Load option. Then "tweak" your video even more with settings provided in this guide. Then go ahead and frameserve.
Hello. -
What do you mean by frameservice and do I do anything different with Virtual dub. And I am not sure what aspect ratio to use.
Thanks -
Thanks TommyKnocker for the help I am encoding now. I have one more question, if FPS is 12.5 how good will the quality Of the VCD ? Is there a certain FPS for movies I should stay away from??
Help-Brand new Laptop terrible quality DVD playback
By Stevethesearcher in forum Newbie / General discussionsReplies: 15Last Post: 29th Mar 2010, 14:53 -
Terrible computer troubles..
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 25th Feb 2008, 03:03 -
Terrible PC troubles..
By SE14man in forum Newbie / General discussionsReplies: 9Last Post: 29th Sep 2007, 15:04 -
First author sounds terrible
By willmoodom in forum Authoring (DVD)Replies: 1Last Post: 2nd Sep 2007, 23:22 -
avi to mpeg quality is terrible
By angelus214 in forum Video ConversionReplies: 3Last Post: 8th Jun 2007, 22:12
