Waht to do if i want to make a vcd from my divx file with a 24 fps divx movie? Is there somekind of programm for too make it an other bitrate.
yes, virtualDub is
How?
Open your avi
VIDEO -> FULL PROCESSING MODE
VIDEO -> FRAME RATE -> CHANGE TO X FPS (X =25, 60,30,23.976,29.976
AUDIO -> DIRECT STREAM COPY
FILE -> SAVE AS AVI
i know it takes a while, but when it's done you'll have a movie in the frame rate you wantWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
If I do it the way you discribe, the file becames much too big. Its more then 4 gb after 3 min and my disk can't handle that much, and after 30 minutes its more then 30 gb possiblily. IS there another way to convert it or am i doing something wrong?
Sounds like your saving it as an uncompressed avi. Select video, direct stream copy. Not full processing mode.
Craig -
If you want to make a VCD from this, just use TmpGenc and encode using the NTSC(film) template. The difference between your 24fps and the 23.97fps of NTSC(film) is so small you won't notice any problems.
Create edit and display movie with 120 FPS
By uridavid in forum Newbie / General discussionsReplies: 1Last Post: 20th Aug 2010, 07:41 -
I need to convert 24p to 30p fps - please help
By Comfy in forum Video ConversionReplies: 3Last Post: 15th Apr 2010, 09:09 -
Convert HD 1280x720 25 / 30 FPS > MPEG2
By squadjot in forum Video ConversionReplies: 4Last Post: 8th Sep 2008, 12:20 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 18:22 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
