Which should be the higher priority in TMPGENC (using Plus 2.58 version), the AVI2(OpenDML) or the Directshow Multimedia File Reader?
When I'm converting a Divx avi file to SVCD, when I'm attempting to preview or use Source Range (to split into 2 mpgs for 2 disc set) I get a system freeze for various lengths of time. It appears that my hard drive is churning away, and eventually the displayed video will "catch up" and I can move the slider again, but at another point it will freeze again. I guess it is taking a while to decode the divx? I have Divx 5.02 installed, btw. Would changing to the Directshow filter make any difference in this or in conversion quality?
Oh, I have a 1.7GHz P4, 256MB PC800 RDRAM, 80GB C: drive and 40GB D: drive (on seperate IDE channels), using WinXP Pro SP1.
Results 1 to 1 of 1
TMPGEnc Xpress - Clip Settings - No setting for 8:9 PAR
By terpsfan101 in forum Video ConversionReplies: 13Last Post: 17th Jun 2012, 05:28 -
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 15:46 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 17:21 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 17:04
