Is there any way to add chapters to a VCD/SVCD image which has already had the bin/cue files created without extracting the dat and then creating a new bin/cue file.
As long as you have your source file and source XML descriptor file still around then, yes.
You can add chapters by manually editing the XML file using the principles outlined here: http://www.vcdimager.org/guides/chapters.html
Otherwise, you should use VCDXRIP (one of the tools in the VCDImager suite of proggies) to extract everything out of the CUE/BIN image and then edit the XML file as detailed above.
You can use VCDXRIP as the command line tool or use a GUI for it (e.g., VCDImager Tools GUI or VCDEasy).
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence -
I only have the cue / bin file .. no xml file.
Could you confirm there is no way to add chapter by editing the cue file other than to use extracting tools like VCDXrip and then recreating with VCDEasy or TSCV.
Yes, you definitely cannot add chapters without reauthoring the CUE/BIN image... There is nothing you can do to the cuesheet that will change this.
Regards.Michael Tam
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 06:14 -
Need to add chapters to a 3GP file
By fredsp in forum Video ConversionReplies: 4Last Post: 22nd May 2008, 04:22 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58
