Hi,
I want to cut a 2Gb mpeg movie to several 700MB disks, and I'm now searching a program that cuts by filesize and not by frames like TmpegEnc. Knows somebody help?
thx
Liganic
bbmpeg crashes after a while. Don't know why, it justs exits without giving an error message. vcdcutter looks nice but only cuts into parts of 1,05 and 1,20 MB (first and second part when selecting "divide into 2 parts") I did not find any setting to correct this... Does anybody know help?
I too have the same problem with BBmpeg. In XP it crashes.
Since I have a dual-boot system, I tried it under Win98Se and it worked fine.
Anyone have any clues about BBmpeg running under XP. I downloaded the XP dll and it still crashes. -
Yeah, there's a bug with bbmpeg. When you first start it, click load under "Input Project" and then press cancel. It shouldn't crash then.
Reduce MPEG-2 filesize without losing too much quality?
By yic17 in forum Video ConversionReplies: 10Last Post: 26th Oct 2012, 08:02 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38 -
Mpeg with dual audio. How to cut off one?
By anfield7 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2007, 23:40
