I have a particular VCD. What I want to do is basically rip the audio/video back out of that and re-edit it. Is that possible?
Thanks.
try extracting(copy/paste) the *.dat file to ur hd w/c is located in MPEGAV folder and convert it to *.mpg using VCDGear.. then burn to NERO..
i guess u dont want the extra movie stuff that goes with it? or for wutever i hope this helps...
Oh man, thank you so much! I had never even heard of VCDGear.
Actaully, what I'm doing is taking some episodes of old cartoons and I'm going to add some extras. I mostly want to add a menu.
Again, thank you very much!
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
New, have some ripping Q's
By RooD in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2010, 10:57 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 22:40 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
