im trying to re-encode a 320 x 240 video resolution mpg file to a compliant one (352x240) via TMPGenc. So far, its OK. what i did was just to center it while keeping its aspect ratio.
now the problem is that it does not re-encode the entire MPG file. it stops at 50:57 while the original MPG movie has 51:33 minutes. it says that the re-encoding process is already done (100%) but upon playing it, the new movie is missing its final minutes. i tried using the source range thing in the advanced setting of TMPGenc and set the last frame manually but it results to the same problem after the re-encoding process.
what could be the problem with this scenario? is my original MPG source the culprit? if so, are there any software to fix/repair damaged MPG files?
pls advise on how to re-encode the movie completely. thank you.
If the source file is MPEG-1, load it into Virtual Dub and select Video
-->Scan video stream for errors.Hello. -
it's possible that the mpeg was joined with a faulty joining package - there were a couple a few years ago that connected the files but incorrectly joined and opened GOP's - the net result is the file plays fine in media player - but anything that actually anylises Gop's fails
Of course this may not be the reason at all -
sometimes
myflix can fix some gop problems
or you can try and find a copy of M2 edit or M1 edit - this can fix most problems even corrupted frames - but good luck getting it to work -
My problem is simaler. However you all are talking about damaged mpg files. I am stressing over a messed up cd-r (svcd) burned from an image file. so I tried extracting with iso (RAW) then tried to de-multiplex with tmpgenc. I don't know If I am doing something wrong or what, but when it gets to the audio part, tmpgenc aint ******* with me!! What I do know is that I followed the advice of a a couple of threads that I saw on here regarding repairing damaged vcds: "How to fix a broken svcd" and it has me
I can't play it in wma, if that helps. And the little bit of video I got when I tried to demux doesn't even make 10 mb. It freezes like 30 seconds into the flick. Once upon a time this was a very viewable movie, and it isn't even scratched up that bad, Ive seen worse that have played. I also tried to load into vdub to scan for errors, but vdub can't recognize avseq. or dat. files. So what do I do? I know that I am not the only one that has had this problem, so somwone come to my rescue!!
budgirl357
Problem authoring mpg file with ffmpegx
By blue439 in forum ffmpegX general discussionReplies: 5Last Post: 14th Dec 2011, 14:23 -
A/V sync problem when remuxing (AverMedia mpg file)
By matomato13 in forum Video ConversionReplies: 8Last Post: 25th Mar 2011, 22:48 -
Problem encoding to .flv - produces Zero KB file in one sec ?!
By toki4004 in forum ffmpegX general discussionReplies: 11Last Post: 25th Jan 2009, 06:58 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 18:12 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
