  1. Hey Guys,
    I was wondering if there was some sort of program that would fix the VOBs of a DVD whose audio is offset, or even a program that would de-multiplex the audio and video stream so I could somehow compensate the audio, any help would be appreciated,
    Thank you
  2. try ac3 delay corrector....I use this process...use smartripper stream processing to get teh m2v and ac3 file....use ac3 delay corrector to fix the audio and import this project to spruceup and watch it first to make sure the audio is in sync...
    just my 2 cents
  3. I'll try it, thanks
  4. One more question is there anyway to stream process the VOBs? Because thats what im working with at the moment, I havent burned the movie yet. Should of been more specific in my post sorry .
  5. well this is the process I use...use dvd2avi to demux teh audio and you'll end up with d2v and ac3 file open tmpgenc and transcode the d2v to mv2 option in tmpgenc video only and you'll end up with m2v and ac3...
    make sure to calculate the bitrate/so the file will fit in 1 dvd and inport those 2 file in spruceup and your set to go..
    just my 2 cents.
