I have DVD rips and would like to economize them and put 2, 3 or even 4 on a DVDr. Is this posible and if it is give me info on whats needed. I have many software apps that do many of these things, but due to lack of time I haven't been able to find the right one. If anyone has suggestions let me know. I would appreciate any help.
Sithlord007
It can be done in dvd maestro if the movie are short enough and or encoded down far enough.... I think one of the guides on this side speaks of it.
I recently put American Pie 1 and 2 on the same disc. I just used CCE to re-encode the video for each film down to just under 2gb and then imported them both into spruce-up with the original DD 5.1 tracks.
Then created a menu to select which movie you want which links to other menus for the specific movie with play movie and chapter selection options. This seemed the nice and easy way to do it -
Very easy to put VCD onto DVD just need to de multiplex the vcd and then put the audio to 48hz rather than 44hz.
Use spruce up or maestro to author.
You can get about 5 disney films sometimes even 6 onto the one DVD. I haven`t used maestro to author with yet, but with spruce up you can get incompatibily problems usually on Pioneer players.
I watch mine on a 34" TV and have had people watch and think it was an original but sometimes if poor encoding or scratched VCDs then can spoil the overall effect. -
I recently burnt a minority report screener on a dvd using vcdgear to change it to a mpg TMPGEnc, spruceup, and finaly Neodvd to burn it. The only problem is that the movie is smaller than it should be and is off to the left. What process did i screw up on?
I used DVD Patcher before SpruceUp i think that is where my problem is. But i followed the directions on http://www.vcdhelp.com/svcddvdr.htm svcd to dvd very carefully. Some please help the its like watchin a 15inch screen on a 27 in tv and for some unknown reason its off to the left.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Clearest DVD Rips
By dudeman316 in forum DVD RippingReplies: 38Last Post: 18th May 2009, 08:33 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 10:29 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
