when opening tmpgenc and using the wizard the first thing it asks for is what format you want to use correct? ok i click ntsc for the 29..whatever fps and on the bottome it says cbr 1150kps 70mins/650 mb.. now the cdrs im using are all 700mbs.. so i have idea why it doesnt have mine listed...
so i leave it and click next. now i open the file i want and hit next twice to get me to the part 4 of 5. now at this screen i have the option of choosing what cdr i am to use. should i leave it at what is set or choose the 700mb cdr. i notice that the output file size is also different dependin on what cdr is used. would that mess anything up if i find the one with the smallest output size and encode regardless of which option for cdr i choose?
chosse cd-r 80min (vcd/svcd). if cbr encode, the file size will be the same no matter what you chosse, but choosing the media that you are burning to will give you a fairly accurate size of disk consumption, especially if you plan to put mutple files on one disk.
Where I walk, I walk alone. Where I fight, I fight alone. -
so i should not worry that my cdr is not in the drop down box at the begginin of the project manager
nope.. it just asks that to tell you how much of the disk your video file will occupy at the end of the wizard.Originally Posted by joeboomonkey
-d
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
