Hey,
I've been trying to rip some of my DVD's to DIVX so that I can play them on my hard drive, using "Pinoy2201's DivX Newbie Guide" (http://www.vcdhelp.com/forum/userguides/78732.php). The problem is, because my Laptop only has a 5GB Hard Drive I cannot rip the vobs AND convert them to a DIVX AVI at the same time without running out of space. Is there any alternative way of doing this or should I just forget about it?
Thanks for your help!
Results 1 to 9 of 9
There are plenty of DVD rippers that rip directly into the divx format. go to google.com and search "DVD Rippers"
go to a link called BurnWorld or something like that. They got a big list of them there -
It's such a big list... could anyone recommend one in paticular?
hi there,
I believe that DVDx can rip directly to DivX. It's free, easily available (http://www.doom9.org/) and VERY easy to use.
good luck
Using DVDx when I click open DVD root and select the movie IFO from the list I get the message:
"DeCSS: Invalid block found; drive may be not unblocked Run a DVD player such as WinDVD or PowerDVD Open the DVD, and retry. The DVD player dosen't need to run during the encoding process"
I click OK and then I get:
"MPEG2Dec: Error during decoder initialisation"
Any ideas?
Thanks for helping out a newbie idiot like me!
(Possible those messages originated because I had already ripped the vobs from the DVD to my HD using DVDDecrypter as instructed with the tutorial I was using) -
you must run a dvd playing program.
this will "unlock" the drive enabling you to rip the movie. -
Thanks everyone for your help, it seems to be working okay now (although 57 hours seems like a LONG time to take
Thanks! -
57 Hours!?? OMG. Why don't you just buy a hard disk and do it with Gordian Knot like everyone else? LOL. I wouldn't even bother if it took this long.
Ripping DVD Tv Epiosdes to Divx
By rlarden in forum DVD RippingReplies: 2Last Post: 31st Aug 2009, 16:09 -
Trying To Make A Very Small DivX
By Anakin in forum DVD RippingReplies: 4Last Post: 12th Oct 2008, 14:17 -
Ripping to divx for use in car
By DikkieDick in forum DVD RippingReplies: 1Last Post: 9th Jul 2008, 23:49 -
Ripping small parts from a DVD
By KingCharlie in forum DVD RippingReplies: 4Last Post: 23rd May 2008, 20:45 -
Directly ripping hardcoded subs on DivX/AVI from DVD
By drstupid in forum SubtitleReplies: 2Last Post: 4th Jan 2008, 16:51
