Whenever I try to mux an audio and video track in MMT it stops after only muxing a couple minutes. The error says that there are too many frame drops. I'm new to MMT; WTF?
What 2 file types are you trying to MUX ? What are the 3 letters after the "." meaning .MP2 or .MV2 etc ...
-Squeed
http://www.squeeds.com
VCD and SVCD Support for MAC -
squeed is right, you did not give us much to work on. Sounds like too high of bit rate. Try the "user" check box.
I tried checking the user box and I got the same results. I don't think the bit rate is a problem. The video is at standard VCD spec. and I encoded the audio with MMT. Here's my terminal output.
cd /Applications/MissingMpegTools.app//Contents/Resources
./mplex -f 2 -O -500 -o /Volumes/Video/PPARTS//movie-%d.mpg /Volumes/Video/PPARTS/pparts_Welcome to Darwin!
vcd.mpg-2.mpg-0.m1v /Volumes/Video/PPARTS/test.mp2
[Jacob-Ss-Computer:~] jacobs% cd /Applications/MissingMpegTools.app//Contents/Resources
[Jacob-Ss-Computer:MissingMpegTools.app/Contents/Resources] jacobs% ./mplex -f 2 -O -500 -o /Volumes/Video/PPARTS//movie-%d.mpg /Volumes/Video/PPARTS/pparts_vcd.mpg-2.mpg-0.m1v /Volumes/Video/PPARTS/test.mp2
INFO: mplex version 2.2.1 ($Date: 2002/02/04 19:06:14 $)
INFO: File /Volumes/Video/PPARTS/pparts_vcd.mpg-2.mpg-0.m1v looks like an MPEG Video stream.
INFO: File /Volumes/Video/PPARTS/test.mp2 looks like an MPEG Audio stream.
INFO: Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: Selecting VCD output profile
INFO: Scanning for header info: Video stream e0 (/Volumes/Video/PPARTS/pparts_vcd.mpg-2.mpg-0.m1v)
INFO: VIDEO STREAM: e0
INFO: Frame width : 352
INFO: Frame height : 240
INFO: Aspect ratio : 1:1 (square pixels)
INFO: Picture rate : 23.976 frames/sec
INFO: Bit rate : 1150000 bits/sec
INFO: Vbv buffer size : 40960 bytes
INFO: CSPF : 1
INFO: Scanning for header info: Audio stream c0 (/Volumes/Video/PPARTS/test.mp2)
INFO: AUDIO STREAM:
INFO: Audio version : 1.0
INFO: Layer : 3
INFO: CRC checksums : no
INFO: Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: Frequency : 48000 Hz
INFO: Mode : 0 stereo
INFO: Mode extension : 0
INFO: Copyright bit : 0 no copyright
INFO: Original/Copy : 0 copy
INFO: Emphasis : 0 none
INFO: SYSTEMS/PROGRAM stream:
INFO: rough-guess multiplexed stream data rate : 1410000
INFO: Setting best-guess data rate.
INFO: Sectors = 18 Video delay = 21618 Audio delay = 66618
INFO: New sequence commences...
INFO: Video e0: buf= 47104 frame=000000 sector=00000000
INFO: Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: Padding : sector=00000000
INFO: STREAM e0: SCR=38432 mux=1 reqDTS=60051
INFO: STREAM c0: SCR=38432 mux=1 reqDTS=105051
++ WARN: Stream c0: data will arrive too late sent(SCR)=192163 required(DTS)=0
++ WARN: Video e0: buf= 34455 frame=000036 sector=00000115
++ WARN: Audio c0: buf= 1349 frame=000044 sector=00000013
++ WARN: Padding : sector=00000000
++ WARN: Stream e0: data will arrive too late sent(SCR)=552469 required(DTS)=0
++ WARN: Video e0: buf= 44799 frame=000130 sector=00000367
++ WARN: Audio c0: buf= 4096 frame=000206 sector=00000061
++ WARN: Stream e0: data will arrive too late sent(SCR)=1769104 required(DTS)=0
++ WARN: Video e0: buf= 34990 frame=000455 sector=00001027
++ WARN: Audio c0: buf= 1924 frame=000773 sector=00000228
++ WARN: Padding : sector=00000186
++ WARN: Stream e0: data will arrive too late sent(SCR)=11975383 required(DTS)=0
++ WARN: Video e0: buf= 39797 frame=003175 sector=00005849
++ WARN: Audio c0: buf= 2477 frame=005497 sector=00001621
++ WARN: Padding : sector=00002469
++ WARN: Stream e0: data will arrive too late sent(SCR)=12335689 required(DTS)=0
++ WARN: Video e0: buf= 44808 frame=003257 sector=00006107
++ WARN: Audio c0: buf= 4096 frame=005639 sector=00001663
++ WARN: Stream e0: data will arrive too late sent(SCR)=12695995 required(DTS)=0
++ WARN: Video e0: buf= 44799 frame=003343 sector=00006363
++ WARN: Audio c0: buf= 4096 frame=005789 sector=00001707
++ WARN: Stream e0: data will arrive too late sent(SCR)=13056302 required(DTS)=0
++ WARN: Video e0: buf= 44799 frame=003428 sector=00006619
++ WARN: Audio c0: buf= 4096 frame=005938 sector=00001751
++ WARN: Stream e0: data will arrive too late sent(SCR)=13416608 required(DTS)=0
++ WARN: Video e0: buf= 44799 frame=003539 sector=00006862
++ WARN: Audio c0: buf= 4096 frame=006131 sector=00001808
++ WARN: Stream e0: data will arrive too late sent(SCR)=13776915 required(DTS)=0
++ WARN: Video e0: buf= 44808 frame=003611 sector=00007126
++ WARN: Audio c0: buf= 4096 frame=006253 sector=00001844
++ WARN: Stream e0: data will arrive too late sent(SCR)=14137221 required(DTS)=0
++ WARN: Video e0: buf= 44808 frame=003681 sector=00007390
++ WARN: Audio c0: buf= 4096 frame=006375 sector=00001880
++ WARN: Stream e0: data will arrive too late sent(SCR)=14497527 required(DTS)=0
++ WARN: Video e0: buf= 44808 frame=003755 sector=00007652
++ WARN: Audio c0: buf= 4096 frame=006504 sector=00001918
**ERROR: Too many frame drops -exiting
[Jacob-Ss-Computer:MissingMpegTools.app/Contents/Resources] jacobs% -
I think that the .M1V file needs to be an encoded mpeg-1 file. If you have a .M1V it leads me to believe that you just demuxed a VOB and are trying to mux it without encoding the MPEG to .MPG-1 for VCD.
Where did the .M1V file come from ?
I think that MUX needs to have the video file be a .MPV file or an encoded MPEG-1 file to work.
-Squeed
Video Re-Muxing Problem: How to Re-Mux to M2TS?
By WellBeSerious12 in forum Video ConversionReplies: 5Last Post: 15th Sep 2011, 02:31 -
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 16:49 -
AVI-Mux GUI problem
By toni-boy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Oct 2010, 12:37 -
ffmpeg mux problem with 2 pcm audiotracks
By thunder25 in forum Video ConversionReplies: 1Last Post: 15th Jun 2010, 08:41 -
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06
