I have some home videos I put to 320x240 mpeg2. I would like to put them on SVCDs, but they need to be in 480x480 resolution for me to do this.
If I can get a tip on how to do this conversion, I'd greatly appreciate it.
You will have to re-encode your film using an mpeg2 encoder software like TMPGEnc or CCE
Resizeing up is probably not a good idea as "what is lost is lost"
If you can recap the VHS tapes again, this time at 480x480
If not just burn the File in Nero as it is, turn "complaint cd" off.
Should work, My DVD player can play VCDs encoded in mpeg2 -
Thanks for the replies.
I just tried a forced burn with Nero - video was jerky/skippy. I really think I need to put in proper format.
I don't have the originals anymore for these few videos I have - wish I did, then I wouldn't be posting this.
I do have TMPGEnc installed - but I couldn't figure out how to load this MPEG2 into it so I could re-encode. I started the wizard, and on step 2 of the wizard it said the format wasn't recognized (?!?). I can play these clips with the Elecard MPEG2 player I have - so I'm sure the video isn't bad. -
Post what I've learned - I see about 300 people have looked at this post - thread - wow.
I used DVD2AVI on my mpeg2 captures. That made a 'raw' AVI file - HUGE. So huge that my original 180K file, after conversion, made over a 3GB file. It also split the video and audio.
So, I still need to read and experiment from here. I'm using TMPGEnc to remake the video in a more standard format (I've found the MPEG2 to DivX page in the Convert section at the left of this forum very helpful). Looks great, but I have a fraction of a second lag between voice and picture. DVD2AVI made the audio file name 'something -723ms lag', so there's a clue. It's in an mpa (?!?) format, so I have to figure out what that is - and when I do, I can use my audio program (Goldwave from goldwave.com) to add or delete time as I need. -
You may be able to save yourself some time on the audio synchronization. In TMPGenc if you choose the source range option (In the wizard, it's on the screen right after you pick your input files), you can use the "audio gap correct" box to adjust the synchronization.
Sometimes there are enough clues to get it right in here, sometimes it's easier to do what you talk about and adjust the audio elsewhere.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
