Can anyone Plz tell me why i constantly get poor Audio Sync After following the step by step guide From Divx to Svcd using Virtual Dub to extract the Audio which aparently according to the guide stops this in most cases.Well in my case it hasent time and again most reacantly trying to make a svcd from a divx source having followed the guide extracted the audio cut the film in half encoded it used Nero burner to make the svcd it was out by quite a bit so i used the usual teqnique ive used before of recording several short clips at the same settings and birate wrote down the audio gap change on each clip played them back on the dvd player found the best audio setting plus or minus then went back and encoded at that setting only to find the end result was still out and in some cases by more than a second.Then i guesed from that and re encoded at the estimated setting and hit it on the head assuming this would be the right setting for the second part of the film i set it the same and then played it back on the burned cdr and this part was out by over 9 seconds EXPLAIN that will you someone plz.![]()
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Plz someone help~ switching audio files in VCL player...?
By OokKyou in forum AudioReplies: 3Last Post: 25th Jan 2010, 22:54 -
plz help my dvd audio is always cracking in my home theater system.
By rex2745 in forum Newbie / General discussionsReplies: 11Last Post: 24th Jul 2007, 05:10 -
Audio Cd Burning (Nero 7 Ultra Edition) NIGGLE... plz help!
By mceyedol in forum AudioReplies: 2Last Post: 30th May 2007, 14:30
