I have a question regarding the size of the mpeg produced by tmpgenc. I am creating a VCD from a DVD rip. I am using 2-pass VBR with min=0, max=4000, avg=2200. Tmpgenc says that the file size should be 800MB but it only ends up around 512MB. I tried it again with a much higher avg but the result was only slightly bigger. Why does it not create a file the size it says its going to? Any help on this subject would be much appreciated. Thanks.
did you change to VideoCD(nonstandard)?
if not press Settings, System tab, change drop down menu to videocd(nonstandard)
you will have to load the unlock in the extras folder to be able to change this.
try it maybe that will work?
"Im just an Idiot offering advice to other Idiots"
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 02:55 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 15:30 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53
