Does this sound feasible?
I have a game running on PC#1 and my goal is to 'record' this game so that I can play it back for others who are interested in seeing it. So here is what I hope could work...
PC#1 will be playing the game
PC#2 will have a capture card
There would be an S-Video out from PC#1 to PC#2
PC#2 will be recording the game
Does that sound doable? If not, what other methods might I want to look into?
Yes you can do that
PC1 will need Video card that has TV out
PC2 there min option as for recording that depend on what screen size you to record in one other thing you to take in count for what format do you want to use?.
I would leave it with the sound on. -
Sound on is a must. Format really isn't horribly important, but the best resolution with passing thought to file size would be the best approcach.
AS far as the TV Out, I have a video card with a S-Video out, is that the same thing?
"Cannot Find Caputure Device"
By SpydaMan in forum Capturing and VCRReplies: 2Last Post: 9th Sep 2010, 17:55 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 00:36 -
Display problem
By PeterW in forum Newbie / General discussionsReplies: 6Last Post: 10th Jul 2010, 17:52 -
TV Display Problem!!!
By tcheema in forum DVB / IPTVReplies: 5Last Post: 20th Feb 2008, 12:01 -
caputure analog video and encode from cam
By greendesert in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 29th Jun 2007, 12:01
