  1. I apologize in advance if this topic has been covered somewhere else on this site. I did a search on several topics and couldn't find anything regarding upside-down video. I recently downloaded a copy of about a boy from direct connect. After installing the Xvid codecs I was able to play the video, however it was upside-down. I have had limited experience with the xvid compression so I'm not sure if it is the compression codec or my player or just something wrong with the rip. I have had one other occurrence of this about three months ago with clockstoppers. I really didn't give it much thought since I wasn't going to watch it anyway. OK i guess my questions are has anyone else had this problem and if so how can I fix it. I would assume it would as simple as taking it into adobe premiere and adjusting the angles. Thanks for any help anyone can give me.
  2. When you installed the codec, i think you installed a fix for the ati-videoadapter. You can either reinstall the codec and uncheck the fix or you can rightclick on the gree arrow down on the systray and check the flipped picture.
    It worked for me
    Tommybj
