Hello
I have just entered the world of VCD and have completed one successfully...but I have just encoded a film from avi to vcd and the first cd plays fine while the 2nd plays, but has no audio...is there any way to add the wav onto an already converted vcd file or will I have to encode the 2nd one again.
Scondly I have d/l a file from the net with name
FILMNAME.CD2.xvid-deity.ShareReactor.avi when I d/l this it said it was vcd......do I need to convert this file or can i burn it and play it on my dvd?
thx in advance
RUK
If you want to get sound on a file with no sound, you have re-encode it again.
Second, to make an AVI file play on VCD, you have to convert it MPEG-2, DVD format, then it can be burned onto a DVD.Hello. -
Thx 4 replying Tommyknocker but I was wonderering ....I read in one of the newbie things that any d/l that is on 2 cd's has more than likely been converted to vcd..but does this mean that it has been encoded to avi for sharing purposes and I will have to encode to vcd again
cheers
RUK -
When you encode the second disk to MPEG-1, why not add the audio then? There is no way to add audio to an already encoded file. You must encode it again.
Hello.
.ts to XviD with AutoGK: Some audio probs?
By vieekk in forum Video ConversionReplies: 0Last Post: 8th Feb 2012, 12:02 -
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 15:23 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 01:23 -
question about an audio file
By marlo in forum AudioReplies: 2Last Post: 2nd May 2008, 16:50 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
