i have made an mpeg file bigger than 4 gb in order to burn it to a dvd it has to be in smaller parts
but whenever i try a program to cut it it doesnt work
is there a tool/way that can handle big files?
tnx for your help
I suggest the source frame function in TMPGEnc. Some may swear by the Merg & Cut function, but it does not like my system.
Anyway, with the Source Frame function, you tell TMPGEnc what part of the original video you want encoded, and the name of the new file. Do this twice, once for part one, once for part two.Hello.
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 19:59 -
Best way to cut out 30-45 seconds of video in an MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 1st Apr 2011, 01:13 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 13:57
