Could someone please explain is as much detail as you wish what the audio/video interleave options actually affect?
1) Enable/Disable audio/video interleaving -- What happens if you disable it? What exactly are you doing my enabling it?
2) Preload XXX ms of audio before video starts. -- Is preloading the same as "playing"? Is this where you fix synch issues? What exactly does "preload" mean?
3) Interleave audio every XXX frames/ms. -- Default is every 1 frame. Why would you need to change it... especially to ms? Isn't interleaving basically "attaching" the audio and the video? Wouldn't you want them to be attached every single frame to keep the audio in synch with the video?
4) Delay audio track by XXX ms. -- Okay, this is where you would adjust out of synch issues, right? I guess that takes me back to the question: What is "preloading" vs. "skewing"? I always though skewing was when something got progressively worse, not necessarily just off a set amount the whole way through?
Hope that makes sense. I'm sure this will be a piece of cake for most of you, and it would help me (and others) understand it all a little better.
Thanks! -- Matt
I've been to Luke's Video before, and I went there again, but I failed to find an answer to any of my questions I posted earlier. If I happened to have been blind, please forgive me and point me in the right direction.
Thanks. --Matt
Ripbot264 audio options
By jamesj84 in forum Newbie / General discussionsReplies: 8Last Post: 8th Feb 2012, 19:22 -
MPEG-4 Muxed Audio Options
By cthompson in forum Video ConversionReplies: 7Last Post: 9th Jul 2009, 19:11 -
Audio / Video interleave Adobe Premiere Pro CS3 problem
By mkrmec in forum EditingReplies: 5Last Post: 21st Aug 2008, 08:28 -
Vdub audio filters causing problem on video track
By SearchQuality in forum AudioReplies: 4Last Post: 10th Feb 2008, 12:42 -
Which Interleave value should i put???
By X_Splinter in forum AudioReplies: 5Last Post: 17th Dec 2007, 12:58
