I have a Acer 8X4X32 CDRW, I used Nero Burning Rom 5.5.9.9 to burn the VCD. Now when I view the window media file on the PC the audio and mouth movements are the way they are meant to be. When I burn the wmf to VCD, the audio is out of sync by about 3 or so seconds, and therefore makes it nearly impossible to watch. I have tried converting the wmf to an AVI File, and it does the same thing, and I have also tried converting it to an MPEG file and it also does the same thing. I have tried burning it on 4 speed and also on 8 speed. I don't know what settings are needed to be used. I have made VCD's before with the same method, with no problems but this one has stumped me. There may be some setting that needs to be changed, and I am in SERIOUS need somebodys help URGENTLY with this matter.
Please post any suggestions as to how I fix this annoying problem URGENTLY. Thanks in advance to anybody who reads this who is kind enough to help me with this issue.
You could try to use this to extract as WAV:
http://www.vcdhelp.com/virtualdubaudio.htm
If you have trouble with extraction ,read this:
http://www.vcdhelp.com/virtualdubaudio.htm#problems"Today is only yesterdays tomorrow" -
Thanks for the info. I have just downloaded Virtualdub, and it doesn't seem to support files with the extension .wmv
I then downloaded the version that one of the links says that should open up the files, and it doesn't want to open it.
Do you know of any other program that may support files with that extension that I would be able to try to make a wav file like you suggested? Or do you know where I would be able to get a patch or something like that, that would make it so Virtualdub will be able to read .wmv files? -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Help: No audio on created AVCHD disc
By SportsorDeath in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 01:43 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 22:43 -
Audio Format created by VOB2MPEG - problem
By linesma in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Jan 2008, 10:46 -
VCD audio out of sync on player
By burnerbie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 10th Aug 2007, 12:15
