Hi Baldrick
Like the title says, if I click on next or 1,2 to see subsequent pages I get
No topics or posts met your search criteria, try use less keywords.
Even though there are 12078 matches on 242 pages.
Cheers
Craig
It is too many hits, same happens if you search for vcd. I will check with www.phpbb.com for solutions.
Solved it. I just increased the size for a temp search column in the database.
But I maybe will delete old topics with no replies to clean up some spaaaace.
Time of front page forum posts
By KiwiKid in forum FeedbackReplies: 2Last Post: 24th Dec 2010, 12:20 -
View poll results on same page?
By chowmein in forum FeedbackReplies: 0Last Post: 4th Oct 2010, 06:41 -
Posts to Off-Topic Forum Visible On VideoHelp's Home Page
By usually_quiet in forum FeedbackReplies: 1Last Post: 26th Jan 2010, 11:25 -
Unanswered questions on processing and compressing DV-AVI
By sd_smoker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 40Last Post: 2nd Jul 2008, 16:31 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33
