ok...say you download a FULL length movie from kazaa or any other p2p prog. and the movie's either smr or tmd.avi.
now after u do this and know the movie plays back A O K.
with these full length movies can u just throw them in TMPGEnc and decode vid and audio all at the same time? then burn as vcd? this just sounds too easy to do IF u can do this with any full length movie u d/l.
or do should you do audio seperatly using virtualdub?
sum1 pls splain the simplest/easiest way to do this plssssssss
and 100% correct way.
thanks
Results 1 to 9 of 9
If the audio has been encoded as a variable bit rate mp3 then it has to be saved out as an uncompressed wav file.
Open the avi in virtualdub, if it gives a vbr audio warning then you have to do the above, if not then there is prorably no need to do so.
Another way to check is to play the video in virtualdub. If the audio is in sync no need to save the wave file. If the audio is out of sync then you need to save as uncompressed wav file.
Craig -
hey tucker...i played the movie in hub..it played the vid fine..same with the sound...i never got no warning...so can i just take that vid n throw it in tmpgenc and start decoding to mpeg then burn to vcd form?
and can i do this same tactic with each movie? as long as the movie plays in virtual hub and i get no warning..i can just pop the movie in tmpgenc and make it mpeg? -
I regularly download movies from kazaa and the first thing I do is open them in VirtualDub. If I don’t get any error messages ,and 9 times out of 10 I don’t, I do a straightforward encoding with TMPGEnc (using the wizard may help if you haven’t done this before). This method seems to work for me.
ok thanks alot guys....this forum is GREAT!!! i know where to come when confused LOL
1 last thing...about this TMPGEnc ..i got version 2.5 and TMPGEnc is only a 30day free trial..when the trials up CANT we use this no more? or do u gotta d/l n install again? or does it still work after 30days is up? -
alright dreamer...thx alot..appreciate it
i was also wondering if u d/l a movie n the res is 352x288 dont that mean its pal format....now when i pop it in TMPGEnc do i gotta change the res to 350x240? is that a MUST DO or do i just burn it a 352x288 as vcd? -
I'm not sure about this one, but check out the link below, it may help.
http://www.vcdhelp.com/tmpgencexplained.htm -
do i ever appreciate this forum ALOT.
ok i downloaded sweet home alabama tmd
it DONT play back in windows media player..iget sum error
BUT it does play back in virtual hub and divx player.
when i right click the movie.avi and properties then details audio says its LAME mp3 encoder (acm) 56kbits 24,000 hz stereo AND it plays back find in virtualhub...so can i just throw it in tmpgenc and make mpeg n burn without any probs?
AVStoDVD help pls!
By merovingio in forum Video ConversionReplies: 1Last Post: 15th Oct 2011, 18:25 -
Avisynth Filters (help pls)
By Enkidu in forum EditingReplies: 14Last Post: 30th Jul 2010, 22:41 -
Hello pls l need help on mhc-gvn111d
By kunxx in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2010, 09:55 -
Problem when encoding...pls help
By Stetsondolly in forum Video ConversionReplies: 11Last Post: 24th Apr 2008, 17:41 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 05:17
