I need some help on burning compliant VCD's with CCE. such as 352*288 or 480*576. i can't find the settings.
this is because most avi files come in a wierd size.
Use VFAPI to framserve to CCE from TMPEG.
Here's how I do it.
1. Open file with Tmpeg using a std template and resize
(clip frame) to remove edge noise etc.
2. Set arrange method (in clip frame) to Center>Custom Size
and play around with the values till you get a satisfactory
picture (not squashed or stretched).
3. Now save project (*.tpr)
4. Open this file in VFAPI and convert(takes a few seconds).
5. Open the vfapi output in CCE. Set video to mpeg1 cbr 1150kbps
and audio to 224kbps stereo.
6. Hit encode and you should have a VCD compliant files within
40 mins. or so. -
thsnks for the help m8
just one more question
1. how do i save as *.tpr. i can only save as *.mcf -
it might be easier, and will definitely be quicker, to use AVIsynth to frameserve your files to CCE
--especially if all you need to do is resize--just 2 lines in your script, and it's done. you'll see a speed increase using avisynth vs. vfapiwhat are you askin' me for...
I'm an idiot! -
i have used Vfapi and it has encoded a new avi. the problem is both CCE and TMPGenc reports an error that the file is curupt?
any help
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 10:45 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 20:52 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 11:10 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 15:37 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
