hi![]()
i wonder what quantization in CCE is, what funktion has it ?, if i change the value up, and down ?
GG smurf
I think the higher the number the more compression it uses, (makes movie/file smaller) the lower the number less compression. Ther might be a formula but I don't know it
thanx,
when i tried the smallest/highest, i saw,
smallest = better quality, bigger file
highest = lesser quality, smaller file
:P :P :P
but, as always, i can have wrong, hehe,
GG smurf -
Think of it as a 'Quality' setting. Your correct. It changes the compression. More compression = lower quality.
Try using 5. It gives good size/quality.Impossible to see the future is. The Dark Side clouds everything...
Adaptive Quantization
By donkeykong in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2011, 08:23 -
XviD Quantization type, H.263 vs MPEG; and GMC for hand recorded material
By carlaron in forum Video ConversionReplies: 41Last Post: 2nd Mar 2010, 23:36 -
HD mpeg2 transport stream re-quantization?
By live4ever in forum DVB / IPTVReplies: 2Last Post: 21st Jul 2009, 20:25 -
Which Quantization (Quantizer) Restrictions Number better? use 1 or 2
By afcoff in forum Video ConversionReplies: 2Last Post: 24th Apr 2009, 08:17 -
TMPGEnc 4.0 Xpress Quantization settings
By gminnick in forum Video ConversionReplies: 8Last Post: 17th Feb 2008, 20:05
