ok hey folks....im kinda new to this burning and decoding thing.
but as far as i know and ive practiced all this b4 burning a full legnth mpeg to vcd to play on dvd player/tv.
anyways whats the difference if you...and i think this is much easier and faster....just use TMPGEnc and load the video/avi ur going to decode and change quality to highest and do the vid and sound at the same time.
beats doing the sound seperate using the virtualdub
do it all together and BAM your done
really only need virtual for resizing the vid if u have too
does this decoding way work 4 any1 else?
Thats fine if the audio stream in your avi file is'nt a variable bit rate mp3. If it is and you don't save the audio uncompressed the sound will be out of sync in your encoded mpeg.
If you open the avi in vdub and it does'nt give a VBR audio warning then ok. If it does give a warning you need to save the audio as a wav file.
Craig
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 23:48 -
Do you see any diff betw default in HD and full HD on YouTube?
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 10th Feb 2010, 13:44 -
VCRs - Multisystem vs Multiconverter - Whats the diff?
By quantass in forum Newbie / General discussionsReplies: 4Last Post: 21st Dec 2008, 17:15 -
ac3/mpeg same on PC, diff. on TV
By spiritgumm in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2008, 07:39 -
Diff languages in Star Wars conversion.
By neomaine in forum DVD RippingReplies: 0Last Post: 5th Feb 2008, 08:06
