I just downloaded an .avi movie and when I open it up in virtualdub it says the floowing "VirtualDub has detected an improper VBR audio encoding... decompress the entire audio stream to an uncompressed wav file and recompress with a constant bitrate encoder." Where can I get a program for that, and what do I do after I get the program.
also
I recently bought a new Panasonic DVD-RV32 player. I have a crappy TV with only and RFU adapter hook-up, and a VCR with an S-Video hook-up. For copyright reasons I can't hook up my DVD player through my VCR to my TV. Is there anything I can do to bypass this without buying an adapter. I went to radioshack and they cost 30 dollars, I might as well buy a new TV if they cost that much.
Thanks for helping a newbie.
Don't worry about that message, i get it all the time, i IGNORE it... And just decompress the audio with VDUB
(in my version, you can click OK on that question, i'm not sure if you're able to do that)Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 17:12 -
[?] Audio Sync & Compression Problems. Trying to start a series.
By shibbuh in forum MacReplies: 2Last Post: 26th Nov 2008, 17:26 -
DIVX DVD Player Audio Synch problem
By wulf109 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Mar 2008, 09:14 -
audio playback problem on television dvd player
By nathy85 in forum AudioReplies: 4Last Post: 16th Nov 2007, 17:17 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 15:57
