how do i convert my uncompliant mpg to a VCD compliant one? i use nero to create VCDs but upon dragging this new mpg that i downloaded, nero prompted me and told me that the mpg is not VCD compliant.
info on the mpg:
frame rate: 29.970
audio format: mono
video width: 320 pixels
video height: 240 pixels
is there a way to re-encode the mpg to make it a VCD 2.0 compliant mpg? pls help. thanks.
Results 1 to 10 of 10
Your video resolution is an obvious culprit. Should be 352x240
Don't know if your mono audio is an issue I encode stereo.
Normally you could ignore Nero and burn anyway but your video will probably not display properly at that resolution.
I did it by accident only once and my picture was shifted to the right.There's not much to do but then I can't do much anyway. -
any other possible solutions? are there any software to convert this mpg to a standard VCD compliant one? all i got is the MPG file. i was just able to download it. pls help. thanks again.
To make a compliant VCD mpeg you will need to re-encode.
You could try to make an XVCD with this mpeg but it will obviously not be compliant.
Regards.Michael Tam
w: Morsels of Evidence -
Nero is good for burning, but not for encoding, when you reencode use
TMPGEnc
Craig -
can i encode a uncompliant MPG file to a compliant MPG file? which program to use? TMPGenc? if so, what are the procedures and best way to re-encode? thanks.Originally Posted by vitualis
Use TMPGEnc and use a standard VCD template. If you use the wizard it guides you through step by step. Very simple.
Craig -
do i still have to create a diferrent audio source file (wav) using virtualdub? or will voice sync be OK already upon re-encoding?Originally Posted by craigtucker
No you only have to do this if you have variable bit rate compressed audio. eg mp3.
So use you existing mpeg as the source for the video and audio.
Craig
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 07:25 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Best way to convert avi to MPG DVD Compliant(highest quality)
By andre477 in forum Video ConversionReplies: 19Last Post: 25th May 2007, 05:59
