I am a newbie and I just made my first VCD! My only problem is that I played it in my DVD and the picture is only on half the screen. Someone please help, I''m ready to pull my hair out!
Is your video resolution 352x240??
I once forgot and put a video at 320x240 and had a similar problem.There's not much to do but then I can't do much anyway. -
What is your source, rip from DVD or convert from avi? How did you encode, frameserve from v-dub to TMPGEnc?
I think your problem is resolution becuz 320x240 isn't really VCD spec. I'd suggest you start to load default VCD template in TMPGEnc (PAL or NTSC depend on your source framerate). -
I convert from AVI using Virtual Dub and Tmpgenc. It was the resolution and it works fine now. Thanks for all of your help!
It did make the picture a little less sharp. Is there anything that I can do about that or is that just the way it's going to look. Still good quality.
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 21:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 17:41 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 12:23
