I followed the directions in the how to guide on this site for making menu's in Nero
The end product is the Menu background which is the picture i inserted does not show up. Also where you can have a thumbnail of the video in a little box, that also does not show up, even though i moved the slider to a specific part in the video to show.
All i get is a black screen. I can however select 1 for track one and it will play the DVD, so all is not a totaly loss.
Any ideas?
Thanks in Advance
Look into DVD Movie Factory by Ulead, it can do that and have sound with your menus, etc... it's also cheap $45.00
You can download a trial copy of DVD Movie Factory from
http://www.ulead.com/dmf/runme.htm -
Okay, so does this program make the menu for you, then you put it in nero somehow?
Easy to use as well?
I am asuming there is a userguide somewhere here for it?
I appriciate your help
TheDeputy -
It has a wizard that asks you what type of disc you want to make – DVD, VCD, SVCD. All you have to do is select your MPEG file…
It will then let you choose a menu format that you can customize.
Movie Factory also burns the disc as well… no need in going between programs…
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
