My Intervideo WinDVR software can capture at a setting of 1/2 DVD or 1/4 DVD.
Is this a standard that will play in DVD players like VCD and CVD?
If by 1/2 and 1/4 dvd you mean 1/2 resolution and 1/4 resolution then probably not. The only valid dvd resolutions are 720x480 and 352x480 (NTSC.)
Half DVD could be considered as a "picture" with a 4:3 ratio and 352x480 resolution (NTSC). Bit rates up to around 4500kbps, and LPCM audio (for greatest compatibility). If you author it to a DVD as a DVD (not VCD,SVCD,CVD,etc.), it should play fine in most players. The quality is somewhere in the neighborhood of VHS without the drop-outs and sync glitches.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Legal resolutions for DVD - Video: 720 X 576/480, 704 X 576/480, 352 X 576/480.
Also legal resolution is 352 X 288/240, but it has to be mpeg 1! No bitrate limitation that way, only GOP limitations (the usual rule: 15 Pal, 18 NTSC).
My extended tests show me that mpeg 2 files with this resolution 352 X 288/240 are also playable. Still to find out if that happens because of the flexibility of the players I tested or because the resolution fools the player and thinks that it is mpeg 1.
