i was using premiere 6.x and exported a movie into avi, but when i tried to convert the avi to mpeg using tmpenc it didnt work. there was an error about being the wrong type of file or something. are there some settings i need to change?
the problem u have here is one of 2 things. first u either have a old version of Tmpgenc and the avi has compressed the adiou wich needs to be removed and decompressed in a wav. file. this will help if that is what the error message is telling u and i think it should be. i would also suggest to go to tmpenc and download there new verison which is a 30 day trial. Good luck and hope that helpsWhen in Dought Just ask. -
jp,
You could do it like that... Capture in this program, Edit in that one, and Convert in another still... Then worry about is the settings right in each of those programs.
OR
You could Capture, Edit, Convert all in one pregram!
Try out Ulead's Media Studio Pro DC... You can download a 30day Trial from their site, to see if it works 4 U.
I use it for everything except burning. The result is a clear, crisp image... No jerking, no microblocks, and the sound is ALWAYS in sync. All you have to do is choose the resolution you want and the bitrate... BAAAMMMM ! its done! -
I find the best (but slow) way to convert avi to mpeg is FX MPEG WRITER from www. jhepple.com and it's free.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Having problems converting FLV to mpeg with Freemake video downloader
By sarbot in forum Video ConversionReplies: 10Last Post: 11th Sep 2010, 21:41 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
Converting Videos to NTSC MPEG-2 (using TMPGEnc Xpress)
By Quamatek in forum Video ConversionReplies: 14Last Post: 12th Sep 2009, 05:20 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Problems converting HD Mpeg
By fearmyrage in forum Video ConversionReplies: 3Last Post: 7th Jun 2007, 22:46
