Hello!
Im editing an already vcd compatible file on premiere, simply because Im adding a fade-in/fade-out effect. I import the mpeg, do all the edit stuff, and then I export it as .mov, but when I play it there is no sound to the movie. Why does this happen? Shall I export the sound file from the original mpg (as .wav for example) and import it as well into premiere? I think when I import the mpg file the sound file comes as well, right? I have checked the option to export the audio. Also, what is the format that I must use to export the file with loosing any data/quality in the compression?
Can anyone help me?
Results 1 to 1 of 1
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 08:20 -
Exporting video and audio as two different files?
By Luka38 in forum Video ConversionReplies: 6Last Post: 15th May 2010, 05:53 -
Mpeg file size balloons after exporting as FLV or MOV?
By jjachin in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2009, 16:56 -
editing and exporting to avchd (bluray) m2ts/mov; vegas/pinnacle etc?
By markm75 in forum Authoring (Blu-ray)Replies: 28Last Post: 24th Jul 2008, 15:02 -
Exporting audio from VideoStudio 9. Possible?
By markannab in forum AudioReplies: 2Last Post: 6th Jun 2007, 20:48
