Ever since I installed the Nemo CodecPack, when I try to play any MPEG's, using WMP or RealOne, I get an application error - "Memory could not be read". Then all the icons in my system tray disappear until I re-boot.
Find the Nimo folder on your HD and click uninstall.
(C:\Program Files\NimoCodec Pack)
Next time just select Basic install, or use the Lite version.
Did help for me. -
Thanks for the tip. I un-installed the Nimo Pack, and everything plays perfect. I have tried to re-install yet b/c I bought VideoWave's latest Movie Creator. If it does everything I need, I won't worry about the codecs.
Which codecs to play .vob files?
By chewie8008 in forum Software PlayingReplies: 21Last Post: 8th Dec 2013, 17:18 -
AVI files with Divx codecs - will they play?
By pooksahib in forum Video ConversionReplies: 7Last Post: 29th Jan 2011, 16:59 -
WMP11 won't play mpeg2 files after installing Catalyst driver
By jrlouie in forum Software PlayingReplies: 0Last Post: 8th Dec 2009, 22:08 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 06:42 -
what codecs do i need to play RMVB in WMP?
By set69 in forum Software PlayingReplies: 12Last Post: 12th Feb 2009, 16:57
