I was happily backing up DVD-movies with CloneAD XP (http://www.clonead.co.uk/) until I changed my motherboard/cpu (from Soyo Dragon Plus/Athlon TBird 1.4 to Abit IT7 max2 / P4 1.8A). Suddenly, CLAD will not even start up anymore. As soon as it loads and detects the disc in the drive, it crashes and closes.
Smartripper 2.41 randomly crashed as well (meaning : it would crash with certain discs, but not with others). I originally switched from Smartripper to CLAD, because it was able to copy ANY dvd I threw at it.
I have now upgraded the firmware on my Pioneer DVR-104 from 1.30 to 1.32. Smartripper works again, but CLAD still crashes. Any ideas anyone?
Apologies if the Moderator feels this belongs in a software-related forum instead.
thanks.
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
2 different types of architecture and you didn't Format your HD and reinstall the OS and all of your programs?
You're asking for trouble and you got it. I'll bet you if you format and reinstall, all of your issues will go away. -
Thanks, but that's not really an option, with 80 gigs worth of apps or so.
I did run the OS install disk and ran the repair utility, which is almost the same as doing a fresh install. Everything else works fine now (including other burning/copying apps, like CloneCD, Nero, Fireburner, CDRwin, Gear Pro DVD, TMPGenc, DVD2AVI, Spruce, etc, etc, etc...)My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Originally Posted by pvanosta
The only other thng I can think of is to reinstall your ASPI layer. -
Why do you want to format and reinstall the OS so much, Burner27. Don't you realize that most people can't do that or it will be alot of work. The good computer user would try to fix the issue with out having to reinstall the OS.
I reinstalled the latest ASPI (linked from the clonead.co.uk website) and CLAD works fine once again.
Thank you all for your input.
PatrickMy system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Sony 8x DVD burner
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 01:59
