Hi,
I was wondering about TV-Tuner cards. If I get one and hook it up to my television, can I watch the .avi or. divx movie files I downloaded without any conversions? Is this worthwile to do or not?
Thanks!!!![]()
TV-Tuner cards generally describe cards that allow you to watch tv or video signals on your PC.
TV-Out cards or features are what allow you to watch you PC output on a TV. -
http://www.vcdhelp.com/capturecards.php?CaptureCard=&Submit=Search&tvtuner=1&Search=Search
that is the tv tuner cards - watching tv on your pc
To watch video from pc to tv you'll need a video card with TV-out capabilities
http://www.vcdhelp.com/capturecards.php?CaptureCard=&Submit=Search&video=1&Search=Search -
So with a TV-out card, would it all work correctly?
I'm glad I asked first, because I was just going out to buy a tv-tuner card today hahaha! :P -
Also, how do I check my existing video card to see if I already have the TV-out capabilities?
A lot of new accelerato graphic cards have TV out which you can connect (yellow composite cable) PC to TV as second monitor. But if you want TV-tuner with TV out then I'd recommend All in wonder 7500. You will have TV-tuner, capture card, TV-out plus graphic card all in one.
How do capture cards get audio when using tuner
By GLE3 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 13:33 -
Are computer tv tuner cards ever counted in tv ratings?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2008, 20:13 -
Opinions on Fusion HDTV Tuner Cards
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2008, 12:02 -
HDTV Tuner Cards with outputs
By jbartosh in forum Capturing and VCRReplies: 0Last Post: 24th Jun 2008, 16:49 -
Need new (cheap) capture solution-what to get? Are TV tuner cards any good?
By wickeddvine in forum Capturing and VCRReplies: 1Last Post: 16th Jun 2007, 09:50
