is there a way to change the framerate and have the sound match in Virtualdub
Why not go ahead and change the framerate and synch it to the audio?
Hello. -
Just capture whatever framerate you can and let TMPEGnc do the frame rate conversion. It sould come out good.
this is a cut and paste to a previos post i responded to-
" had a 45minute 7 sec pefectly synced avi(dbz 5-cooler's revenge) i wanted to encode to svcd with dvd2svcd. the original framerate was 23.980 fps. when i load into dvd2svcd, the framerate would be adjusted to the standard of 23.976. as you can see, the audio would have a gradual lag that would be about a second ahead of the video by the end of the movie.
so what i did was load the avi in virtualduband save the audio as a wave. then i adjusted the framerate of the video from 23.980 to 23.976 and saved it(video only) in direct stream.
then i reopened the save video in vdub, and checked the file properties. i devided the # of frames by the framerate(23.976) and got a number in seconds. i wrote this number down.
next, i opened the audio in sound forge. i used the time strech option, and shrunk the time down to match the time(that i wrote down)of the video. i then saved the the new wav with 320kbs mp3(yes its a wav).
then i loaded the adjusted video in vdub. on the audio tab i selected "wav audio" and loaded the adjusted wav. then i selected direct stream processing for both audio and video. then i saved the new avi."
i think you can adjust some of the steps in what i wrote to help you out.Where I walk, I walk alone. Where I fight, I fight alone.
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 10:27 -
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 19:58 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 02:32 -
changing frame rate, making a better dvd picture
By motleycool in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 02:30 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
