Results 1 to 9 of 9
Thread: PROBLEM CHANGING FILE TO IMPORT INTO HEADAC3HE
  1. #1
    Member
    Posts
    123
    Hi
    I've extracted the audio ac3 out of virtualdub direct stream and saved to wav. as in the guide. The problem is when I try to change the file type into ac3 audio the file becomes unstable, and changes to a dat file. As this happens I can't load this into headac3he. Can anybody help me out ?
    many thanks
    Member Craig Tucker's Avatar
    Apr 2001
    England
    Posts
    7,904
    When you select save wav in vdub give the filename the ac3 extension then, dont try to remane it later.
    So file - save wave - call it "whatever.ac3"
    Craig
    Member
    Posts
    123
    Hi craig
    Tried what u said but still no result. When tried to import the file it still gives error, can not open file. Any more idea's
    many thanks
    Member
    Jul 2002
    Erie, PA United States
    Posts
    490
    k b,
    Did you save it as "all files"? If you didn't VirtualDub stuck a wave header on it and thats why HeadAC3he keeps rejecting it.
    Warning! I'm baaaaaaaaack
    Member
    Posts
    123
    Hi Kayfam
    Just tried saving the extract in all files and still it keeps putting wav on the end. Preventing the headac3he importing it. Any more thoughts?
    many thanks
    :P
    Apr 2001
    England
    Posts
    7,904
    Try putting it in quotation marks
    eg "file.ac3"
    Craig
    Member
    Posts
    123
    Hi craig
    Tried saving it as u said, the file was able to be imported but the following
    was stated in headac3he;
    Warning:
    Source file's last frame incomplete
    or corrupt stream
    Yet when the avi film is played in either zoom player or w m player all the
    audio is intact.
    Have u got any more ideas
    Many thanks
    Member
    Jul 2002
    Posts
    490
    k b,
    Ignore the warning and just do the conversion. I see it all the time with avi files encoded with ac3 audio and have yet to have a problem. The only reason I can think why this happens is because of the way the original file was cut in the first place.
    Member
    Posts
    123
    Hi
    Tried the last two solutions to my problem and they seemed to work.
    thanks very much for your imput
    Now I can watch yet another film, cheers.
  1. Replies: 1
    Last Post: 28th Nov 2011, 19:04
  2. File thumbs changing after conversion...Is this a problem?
    By llllllllll in forum Newbie / General discussions
    Last Post: 10th Mar 2011, 12:21
  3. Replies: 37
    Last Post: 10th Oct 2010, 07:28
  4. color changing problem in .sup file
    By akakiami in forum Subtitle
    Last Post: 14th Oct 2008, 03:09
  5. changing ifo file names on same file ext of diff dvd files
    By holliquinn in forum Newbie / General discussions
    Last Post: 5th Jun 2008, 05:02
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
