I have convertet the audio with virtual dub (using the guide here) and used TMPGEnc to make the vcd but the audio is out of sync. Can anybody tell me what can be wrong ? and/or how to fix it.
I’m not an expert at this. I can tell you some of the things that I have learned and save me time. I make XSVCD’s only, as I’m converting home videos to CD. I have managed over time to get it down to 4 easy steps.
Step 1: Capture the video as uncompressed AVI (this gives you the best quality to work with) as close to the final output resolution as you can. This will save encoding time if it does not have to resize it. In my case 480x480 or 640x480
Step 2: Edit the captured video. I use Media Studio Pro 6.5DC for this.
Step 3: Save the edited video in Media Studio as an MPEG2 480x480 with a VBR of 4000. Field order B first. (make sure your player can play this).
Step 4: Burn the MPEG file(s) to CD with DVD Movie Factory. Make your menus etc…
That’s it!!
You can download a trial copy of Media Studio Pro from
http://www.ulead.com/msp/runme.htm
They also offer upgrade offers from other editing software – so you can get it as cheep as $129.00 for the DC version.
Works every time and I get video as good as the original… I would say its DVD quality. Audio is ALWAYS in sync and I never have microblocks. The down side is I can only get 20-30min per CD with a bit rate that high… but with this quality, I’ll take it! -
Is the audio out of sync by a constant amount all the way through, or does it get progressively worse.
Craig
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
