I have this really crappy TV which only has a coaxial cable input (cable wires). And I just got a new APEX DVD Player and it only has digital output (yellow, red, white wires). So I can't connect it directly to my TV.
I don't want to buy a new TV (with digital inputs) or a VCR (digital to VCR, and VCR cable to TV), so I want to see if there was a work around, sooo...
Is there something small that I can buy that will allow me to connect these two devices together?
If there are no audio video connectors I dont think there's anything you can do. I don't believe they make anything that can go from composite connectos to coax. Also, the red, yellow and white connectors are analog not digital.
Yes, they do make a converter box for this. I have one. I think I got it at Best Buy, but I've also seen them at Radio Shack.
Lizzo -
By the way, those outputs are not digital, just plain old analog left /right audio and composite video.
Look for an RF Modulator.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Dolby Digital 5.1 -> PC input?
By Asterra in forum AudioReplies: 1Last Post: 4th Oct 2011, 01:38 -
Digital optical vs. digital coaxial cord
By coody in forum AudioReplies: 3Last Post: 12th Dec 2009, 09:57 -
How to decode Dolby Digital from SPDIF input?
By Try4ce in forum AudioReplies: 12Last Post: 17th Feb 2009, 17:53 -
By x2srj in forum AudioReplies: 0Last Post: 8th Sep 2008, 07:48 -
can i use coaxial input for DVD player 1, toslink for player 2?
By buzzinhornets in forum Off topicReplies: 3Last Post: 23rd Aug 2007, 18:11
