when i try to convert avi file to mpeg for vcd i get no video showing up when i go to cut parts out of the video. the are codec div 3 and 4 what do I need to do?![]()
StormStrickland
I’m not an expert at this. I can tell you some of the things that I have learned and save me time. I make XSVCD’s only, as I’m converting home videos to CD. I have managed over time to get it down to 4 easy steps.
Step 1: Capture the video as uncompressed AVI (this gives you the best quality to work with) as close to the final output resolution as you can. This will save encoding time if it does not have to resize it. In my case 480x480 or 640x480
Step 2: Edit the captured video. I use Media Studio Pro 6.5DC for this.
Step 3: Save the edited video in Media Studio as an MPEG2 480x480 with a VBR of 4000. Field order B first. (make sure your player can play this).
Step 4: Burn the MPEG file(s) to CD with DVD Movie Factory. Make your menus etc…
That’s it!!
You can download a trial copy of Media Studio Pro from
http://www.ulead.com/msp/runme.htm
They also offer upgrade offers from other editing software – so you can get it as cheep as $129.00 for the DC version.
Works every time and I get video as good as the original… I would say its DVD quality. The down side is I can only get 20-30min per CD with a bit rate that high… but with this quality, I’ll take it! -
Sorry´, that´s not that kind of stuff im dealing with. I thougt you meant avi from the internet. Try to use Tmpg and use the including templates for DVD, SVCD, VCD
thank you movman that is what i was talking about but i had just figured out what was wrong i didnt have my codecs on lol i am a bit slow
StormStrickland
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
converting mpeg to avi or to wmv
By stevenr2 in forum Video ConversionReplies: 4Last Post: 11th Jan 2010, 16:56 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 13th Dec 2009, 00:44 -
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 14:07 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 14:35
