I have a movie that is more than 4.5g and I use tmpgenc to transcode it to get a smaller file.. method use ....rip using dvd decrypter ..got vob file used dvd2avi tool to demux audio to get d2v and ac3 file use tmpgenc to transcode video only and I get my m2v file..use spruceup to compile and the audio is out of sync..
from what I heard I don"t really need to touch the ac3 just the d2v to transcode the video..
any ideas as to why the audio is out of sync??
any help will be appreciated
thanks
Look at the file name for the AC3 file. Was there a delay? That could cause it. I personally use CCE for re-encoding and I never have any audio sync problems. I also use Scenarist for authoring.
Look for the program AC3 Delay Corrector. Load the DVD2AVI demuxed AC3 file into the program and it will set the correction automatically by reading the delay value from the filename. Press the Write button and wait for it to create your new AC3 file without delay.
just out of curiosity (shoot me if i'm wrong) can't you just remux them at the same time you are re-encoding with tmpgenc ?
OK I'm loading my gun right now......just messin wit ya..lol
Originally Posted by rieklcheck out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
sorry for not responding on this but I was busy with work... but I was able to fix the audio problem by readin gon the post about murder by numbers...and thanks enemywithin I did use the ac3 delay corrrector to correct the audio...
thanks people for the info
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
