Closed Thread
  1. at the bottom it always says aspi seems valid:no and when i try to burn it says ERROR: Cannot set write parameters mode page. Try to change the driver in using "Force Driver" in the "CDRDAO settings" page
    ERROR: Simulation failed.
    at the end help!!!!!!!!1
    Nov 2001
    Sweet Home Alabama USA
    Click on the link to the right of the Setting CDRAO "Force Driver" drop-down and determine which driver is correct for your writer, then select that driver from the drop down list. VCDEasy is buggy on CDRAO integration. Sometimes I would get an error, change the driver, get an error, then change it back to Generic-mmc, reboot and presto it works. If you found your writer in the list and have that driver selected but still get an error, keep screwing with it and reboot.
  3. Please don't post the same question on several forums.
    http://www.vcdhelp.com/forum/viewtopic.php?t=118461
    Regards.
    Michael Tam
    w: Morsels of Evidence
